Unknown USB device
shorty22
(@shorty22)
Unknown USB device
I did my MK3S upgrade and now i need to do a firmware upgrade but i cant get the drivers to install correctly so there is no port assigned to my printer. I'm not sure what to try next. nothing seems to work. I have a new desktop windows 10 its up to date i tried the newest prusa software version and 2.5. any ideas would help. thanks
Postato : 01/08/2020 3:24 am
jwvaughn
(@jwvaughn)
RE: Unknown USB device
Try doing the installation as an administrator - right click on the installation file then select Run as Administrator.  Just a thought to try...
Jerry
Postato : 01/08/2020 4:34 am
towlerg
(@towlerg)
Be careful that you get the right firmware, there a several posts by peeps with problems eventually chased down to wrong firmware.
Postato : 01/08/2020 1:47 pm
shorty22
(@shorty22)
Running as admin didn't help and i can't even get the the firmware update part, but when i can ill make sure
Postato : 01/08/2020 2:59 pm
jwvaughn
(@jwvaughn)
Are you getting any error messages during the install?  What are the symtoms you are seeing?  What does devicc manager tell you about the com ports?
Jerry
Postato : 01/08/2020 6:03 pm
shorty22
(@shorty22)
no errors at all other than the device being unknown
it says "unknown usb device device descriptor request failed"
which i think is a generic windows driver issue
Postato : 01/08/2020 6:11 pm
jwvaughn
(@jwvaughn)
Have you installed the Prusa Drivers and Apps? You cannot install firmware until you do.
Your original description lead me to believe that was where you were having issues. Now it sounds like you are trying to update the firmware but Windows does not understand anything about the device. Once you have installed the drivers, in Device Manager you should see Original Prusa i3 MK3 (COM ?) where ? is some comport number.
Here is the link: https://cdn.prusa3d.com/downloads/drivers/prusa3D_win_2_3_0.exe
Postato : 02/08/2020 1:32 am
shorty22
(@shorty22)
The goal is to update the firmware.
the problem is that the computer doesn't see the printer. all i get is an unknown device in device manager.
i have the new apps and drivers downloaded and installed but nothing ive done has helped windows see the printer correctly. there is no port assigned since the device isn't installed correctly.
I just ordered a new board. there is nothing i can find thats helping me so a new board is the only other idea i could come up with. Thanks
Postato : 02/08/2020 2:41 am
Hi Mike,
Have you tried deleting the Prusa  sections in Windows10 Settings  Apps and features
then re loading them?
Postato : 02/08/2020 2:36 pm
shorty22
(@shorty22)
@joantabb
You mean uninstall then reinstall everything right? yes ive done that a few times.
theres the regualr app and all the driver packages. ive removed all of them a few times
Postato : 02/08/2020 2:47 pm
@mike-s33
Doh!
Windows10 sometimes is a world of pain.
I bought a gaming laptop to get a discrete video card for some 3D modelling packages.... however I could never get them to work with the gaming laptop and win10, so that resides at home, largely unused
Best wishes,
Joan
Postato : 02/08/2020 2:51 pm
jwvaughn
(@jwvaughn)
Have you tried either using the USB cable on another device or a different cable on the Prusa?
A different USB port on your computer?
Jerry
Postato : 02/08/2020 3:43 pm
shorty22
(@shorty22)
Yes i have tried a windows 10 desktop and laptop and a windows 7 desktop with 3 different cables one of which is the original prusa cable that it used to work with.
Postato : 02/08/2020 7:19 pm
jwvaughn
(@jwvaughn)
With all the new info it really does point to the board as being the problem.  A final thought, have you tried a full reset?
Good luck!
Jerry
Postato : 03/08/2020 5:22 am
Prusasg
(@prusasg)
Posted by: @shorty22
I'm running into this exact problem now. Did you ever find a fix for it?
Postato : 29/11/2022 5:20 am
Hello
(@hello)
There are many things to try factory reset computer install USB drivers some apps can mess with serial communication
Postato : 15/12/2022 7:03 pm
Doticus
(@doticus)
in my case, i was using a usb hub and that didn't work.   eliminating the hub made it work correctly.
Postato : 28/11/2023 4:48 pm
