Unable to read SD cards
Page 1 / 2
Nick-i3mk3s
(@nick-i3mk3s)
Hi all,
I'm currently facing an issue I'd like to get some community feedback/input on.
My Prusa i3 MK3S stopped printing in the middle of a print, without any clear reason, and refuses to read SD cards since. See this video for the behaviour experienced when loading/unloading SD cards: https://www.dropbox.com/s/67c1ets35s1gejm/GH014943.MP4
I've already tried with multiple SD cards, and they all show the same behaviour. All SD cards can be read by a laptop (OS: Linux Mint 20.2) so I'm quite sure the SD cards or their formatting are not the issue.
Also notice the odd °°°°°°°° signs displayed by the Prusa instead of the usual progress bar, and the truncated/scrambled menu options.
It should be mentioned that the system behaves normally aside from the SD card issues: the printer preheats nozzle and bed as normal, and can also move axis using settings.
Has anyone seen this problem before? Any suggestions on how to fix it?
Many thanks in advance for your thoughts!
Nick
Publié : 17/01/2023 12:22 pm
Historically there have always been potential problems with the physical sd card holder.  The frame which is just thin metal can get bent out of shape during insertion and cause issues. Please have a read of https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/fix-for-sd-card-reader-error-no-card/
its an old thread but most of the info should be applicable still.
Publié : 17/01/2023 12:36 pm
Nick-i3mk3s
(@nick-i3mk3s)
RE: Unable to read SD cards
Thanks for the reply @neophyl. I conducted a thorough visual inspection and couldn't find anything obviously wrong with the SD card slot. It doesn't appear bent or damaged, and the software registers correctly when a card is inserted or removed. Rather, it appears that reading data from the card is an issue. When inserting the card, instead of a progress bar, I just get dots (° signs). After a few moments it shows a broken empty file structure and the Info Screen return option. When the card is removed, that is detected and reported on screen. See screenshots below.
Everything else appears to be working correctly, I can print using Pronterface over USB without any problems. It's just printing from SD cards that appears to be an issue.
Because everything else is working correctly, I would suspect that it's the physical SD card slot that is not working. Would you recommend trying to replace the SD card slot? Or do you have other suggestions?
Kind regards,
Nick
Publié : 13/10/2023 9:30 pm
Ah in which case what is the format of the cards contents ?  The file system is pretty limited, if you have certain special characters in a file's or folder name then it can break the directory read. Basically stick to alpha numerical (A to Z, A to Z and numbers and you should be ok. Spaces and underscores are also ok but things like % are not.
Publié : 13/10/2023 10:16 pm
Nick-i3mk3s
(@nick-i3mk3s)
I've tried multiple cards, including the original one, always formatted FAT32. The problem occurs even with blank cards that don't have any files on them.
Publié : 13/10/2023 10:33 pm
Try sticking a patch of masking tape or similar on the back of the card in case it's just a little wear - the extra thickness may be enough to maintain the contact.
Publié : 13/10/2023 10:43 pm
Hello
(@hello)
Well it seems it's sensing the sd but carnt read it try reaseat lcd cables
Publié : 14/10/2023 1:16 am
Nick-i3mk3s
(@nick-i3mk3s)
@diem I tried the masking tape suggestion but as expected, it didn't make a difference because the card was already detected correctly it's just the reading that seems a problem.
@hello I'd checked the cables and they are plugged in properly on both sides. I've also swapped the cables on both sides, and exactly the same behaviour so its not one of the cables causing the problem.
Publié : 14/10/2023 8:14 am
Hello
(@hello)
Posted by: @nick-i3mk3s
Then it sounds like the boards toast to confirm you checked all pins inside sd card holder
Publié : 14/10/2023 8:33 am
Nick-i3mk3s
(@nick-i3mk3s)
The pins look properly soldered on the outside, but had to look for corrosion on the inside. What procedure would you suggest to check the pins inside?
Publié : 14/10/2023 11:27 am
Hello
(@hello)
Just use a torch and look for bent pins there most likely won't be corrosion
Publié : 14/10/2023 6:59 pm
Before doing anything drastic try cleaning the pins with ispropyl alcohol - fold a thin strip of cloth over the end of a screwdriver and dip it in the alcohol - and check your electrical connections at both ends of the ribbon cable in case a plug has vibrated loose.
If that fails I'm with @neophyl, characters out of range, this includes 'invisible' characters, ones where the glyph is a space - also those in directory names if you use them; keep to the ASCII subset.
Make sure you are using FAT32 and not a FAT32 image inside another filesystem.
Try with a small SD drive - 4GB or less (calling 4GB small seems odd considering how recently that would have been unimaginally huge.)
Publié : 15/10/2023 8:14 am
Nick-i3mk3s
(@nick-i3mk3s)
I followed your advice to clean the pins internally with IPA, @diem, but it doesn't seem to make a difference. It's hard to say whether I was pushing the screwdriver deep enough, admittedly
I think the next thing to try is to replace the SD card holder completely, but I can't find documentation for this board; does anyone know where/how to find the part number for the SD card holder? There are so many different SD card holders and they don't seem to be pin compatible, so want to make sure to order the correct one.
Publié : 15/10/2023 10:27 am
Where in the world are you(not street address)?  Is there someone nearby who could lend you a known working SD card with a couple of gcodes installed.
https://world.prusa3d.com/en
Publié : 15/10/2023 11:47 am
Nick-i3mk3s
(@nick-i3mk3s)
That's something I hadn't thought about, I'll have a look at the map and message users in the neighbourhood to ask if I can borrow a known working SD card. Will report back on the results. Thanks for the suggestion @diem!
Publié : 15/10/2023 7:23 pm
Hello
(@hello)
TRy flashing 3.11 firmware if it was the sd card you would not be getting rhe first 2 image you shared
Publié : 15/10/2023 7:26 pm
Nick-i3mk3s
(@nick-i3mk3s)
Posted by: @hello
Printing via USB works fine though, so wouldn't that suggest it's not the firmware that's the problem?
Publié : 15/10/2023 7:30 pm
Hello
(@hello)
Posted by: @hello
How does Printing via usb have anything to do with the SD card reading firmware
Publié : 15/10/2023 7:32 pm
Hello
(@hello)
Printing via usb just sends gcode commands
Publié : 15/10/2023 7:33 pm
Nick-i3mk3s
(@nick-i3mk3s)
I know, my question was rather, how does changing the firmware help with diagnosing the problem? If printing via USB works, then that leads me to conclude that the firmware currently running on the printer is not corrupt, so what would be the advantage of changing it?
Publié : 15/10/2023 7:36 pm
Page 1 / 2
