True Maximum Print Height (i3 MK3S)? 210mm or 250mm?
ben_r_
(@ben_r_)
Seeing some conflicting information here that really should have been cleared up a long time ago on Prusa's part. What is the actual maximum print height of the i3 MK3S? 210mm or 250mm? Their webpage for the i3 MK3S shows both and the current version of PrusaSlicer defaults to 210mm.
Best Answer by bobstro:
Posted by: @benr
The WIDTH is 250mm. Height and depth are 210mm. The items you noted are correct. X is 250, Y is 210, Z is 210.
Ce sujet a été modifié il y a 7 years par ben_r_
If at first you don't succeed, redefine success!
Publié : 24/12/2019 3:33 am
RE: True Maximum Print Height (i3 MK3S)? 210mm or 250mm?
Posted by: @benr
Publié : 24/12/2019 7:20 am
ben_r_
(@ben_r_)
@bobstro
I see! Well that would make sense. That's what happens when you drink and print! lol Thank you for clearing that up for me. 👍
Ce message a été modifié il y a 7 years par ben_r_
Publié : 24/12/2019 7:41 am
