Tried everything, extruder still overheating causing jams
benjamin.s17
(@benjamin-s17)
Maybe someone can help me. The extruder motor is getting insanely hot melting part of the filament that then jams. It is already the fourth time I have to disassemble the Extruder within two month. Already tried printing slower, putting a heatsink on and getting the new extruder body and just ever so slightly tightening the bondtech gears. All to no avail. 🙁
Opublikowany : 09/08/2018 9:05 am
AbeFM
(@abefm)
Re: Tried everything, extruder still overheating causing jams
It's soon to be definative, but I've had the same issues, and I have two things I'm trying - the first helps.
I think something like this but more permenant is in my future. The temp of the motor housing dropped by 10 degrees for 1W of fan. I think tuning the layer fan around so it draws OFF of the motor might help, with a heat sink.
Secondly, I took a little stab at the new shroud:
I added a little paper towel as a guide to keep the air flowing over the cooling fins more instead of sneaking out the sides hardly going over the heat sink at all.
I'm not super sure, but I had clicking that went away with both changes.
I maintain an informal list of San Diego, CA 3D printing enthusiasts. PM me for details. If you include a contact email and I can add you to the informal mailing list.
Opublikowany : 09/08/2018 10:05 am
