Time Remaining
I just printed the new extruder assembly provided with the last update. I noticed that it included a time remaining instead of time elapsed field. How can I include that with models that I slice in slic3r or prusa control?
Thanks,
Mike
Re: Time Remaining
You will need Slic3r PE 1.41.0-alpha3 and firmware v3.3.0 and higher.
Re: Time Remaining
and then what? how do you turn it on in the slic3r?
Re: Time Remaining
You don't have to do anything 😉 Slice the parts, export Gcode and time remaining will magically appear on your printer LCD. Atleast that's how it worked for me 😀
Re: Time Remaining
If you are running current firmware and using recent Slic3rPE, it should just show up. If it doesn't, check Printer Settings->General->Firmware->Supports remaining times.
[...] and then what? how do you turn it on in the slic3r?
Re: Time Remaining
Oddly, one of my printers (3.4.1 firmware, 1.41.0 Slic3r) shows time remaining, then R?
The other works as expected.
That's weird. Any suggestions?
