Time Remaining
mike.w12
(@mike-w12)
Time Remaining
I just printed the new extruder assembly provided with the last update. I noticed that it included a time remaining instead of time elapsed field. How can I include that with models that I slice in slic3r or prusa control?
Thanks,
Mike
Respondido : 01/09/2018 6:38 pm
LaPointe
(@lapointe)
French moderator and translator Moderator
Re: Time Remaining
You will need Slic3r PE 1.41.0-alpha3 and firmware v3.3.0 and higher.
Respondido : 01/09/2018 10:52 pm
Chris
(@chris-16)
Re: Time Remaining
and then what? how do you turn it on in the slic3r?
Respondido : 02/09/2018 8:34 am
Maxime L
(@maxime-l)
Re: Time Remaining
You don't have to do anything 😉 Slice the parts, export Gcode and time remaining will magically appear on your printer LCD. Atleast that's how it worked for me 😀
Respondido : 02/09/2018 9:45 am
Re: Time Remaining
[...] and then what? how do you turn it on in the slic3r?
If you are running current firmware and using recent Slic3rPE, it should just show up. If it doesn't, check Printer Settings->General->Firmware->Supports remaining times.
Respondido : 02/09/2018 5:02 pm
TJH
 TJH
(@tjh)
Re: Time Remaining
Oddly, one of my printers (3.4.1 firmware, 1.41.0 Slic3r) shows time remaining, then R?
The other works as expected.
That's weird. Any suggestions?
Respondido : 17/10/2018 3:54 am
