Thermistor wire broken or?
krilleric
(@krilleric)
Hi
Need some expert advice.
I did a crucial design miss and when I printed it I also missed the support settings so it resulted in that the printer tried to print a gap which ended with a mess and blobs a little bit everywhere.
So I tried to remove the big blobs with a plier and then I scrubbed the rest with a brass brush (as seen in a video)
I don´t know if I did any damage to the wires, because it prints fine and the temperature seem to be steady, so how do you know if something is wrong?
I attach some before and after cleaning pics, and I dońt know if you can if itś something wrong.
There are a small blob right where the wires are (I think) can that be removed by using a hair dryer or something?
The last thing is a pic of my design miss, next time I will look at it from all angels, but Ím new to this so I´m excused 🙂
Hoping for help
Krister
BEFORE CLEANING
AFTER CLEANING
SLIGHTLY DESIGN MISS 😀
Respondido : 23/03/2019 2:49 pm
Bunny Science
(@bunny-science)
Re: Thermistor wire broken or?
If you damaged thermistor wire or heater wire significantly, you would already see error warnings from the printer during printing. I believe you succeeded in cleaning off the blob without breaking things. I wouldn't concentrate too much on the little blob at heater wires. Most I would do is have the heater block at temperature and gently do a little cleaning with a toothpick. That blob isn't going to harm function and trying to get it all off risk damaging those stiff wires.
Respondido : 23/03/2019 6:23 pm
krilleric
(@krilleric)
Thank you I´ll feel much better now and I have also learned a valuable lesson when it comes to design checking
Thanks!
Respondido : 23/03/2019 6:54 pm
