Thermal Anomoly / REVO 6 possible problem
charles.t
(@charles-t)
Recently upgraded to the REVO6  and it worked fine for a couple weeks, very nice prints...
Then I had to do some maintenance on my MK3, belt tightening etc.......
performed a complete WIZARD set up and all was back in good working order..
The last two days I have had issues with Temperature and THERMAL ANOMALY popping up on a regular basis...
One of the items I noticed about the REVO6 was the interconnects that they us instead of a full constant wire back to the controller.
Being in the industry for 50+ years I look at this with dismay but ignored my better instinct and just assumed this would be ok.
This morning after a THERMAL ANOMALY every 2 minutes I decided to look at the REVO6 Temp Sensor connector, (black  two wire)
and from experience decided to bend the inside female mating connector inward to allow a tighter fit when plugged into the male side.
I also put some silicone grease on the connections DOW CORNING 4 to help with oxidation even tho I am in a office environment, this practice
has served me well , especially with all types of battery operated devices to keep the dissimilar metals from acting up.....
this seemed (for now) to get rid of the anomaly.... 15 mins now and no issues.....
I would recommend to REVO folks that this connector has to go....
While it is a nice feature for manufacturing and packaging, it is a end-user issue waiting to happen......
For the folks that may be having this issue with a REVO installed I suggest to cut the conn's off and just solder the wires and use heatshrink for a final
install that will last...
( I will be doing this to mine soon as time allows)
Hope this helps anyone that has a REVO6 installed and may have seen this issue..
Chuck
Napsal : 26/01/2024 12:21 pm
M.Ruess
(@m-ruess)
RE: Thermal Anomoly / REVO 6 possible problem
Thanks, @charles-t! Saved me a second/new prusa printer :D. I almost threw it in the trash...
- changed Firmwares three times
- calibrated thermal model hundred times (temp error/anomaly)
- calibrated Z hundred times (error occured almost as oftes)
Now, after 10 min of work, it's back up running flawlessly like before. My hero of the day!
Napsal : 31/01/2024 1:01 pm
Corinne Laisne
(@corinne-laisne)
Posted by: @charles-t
Chuck
Thank you, you helped me a lot with my problem
Napsal : 01/02/2024 8:42 am
Jeremy
(@jeremy-11)
I had a melt out so i replaced the casing. Replaced the sensor and heatblock and heating rod. I updated the flash already. I keep getting a thermal anomaly error, then it starts to cool down. I would clear the error and go back to losding the filament and this happen a few times. I was able to to the first layer, then had to do the same cycle and now it is printing fine. So i don't get the error when i reach the right level, only when it is heatin up. Thoughts?
Napsal : 12/06/2024 12:32 am
Paul beard
(@paul-beard)
Wow. I just installed this and ran the tests (PID and thermal calibration) but it won't heat up past 80* without a THERMAL ANOMALY warning. If this is due to those connectors, that's very disappointing. I assume it's the thermistor not making a good connection that does that? Am I really going to have to strip and solder these? Not my favorite task and connectors exist, where used correctly. I should have guessed it was going too well.
Napsal : 08/03/2026 10:02 pm
Paul beard
(@paul-beard)
aha. There may be a less annoying solution. I followed the directions here to overwrite some values in the PID tuning setup that don't get set properly. I ran it and now I can load filament and print. ¯\_(ツ)_/¯
https://www.reddit.com/r/prusa3d/comments/181s35v/fixing_the_revo_6_thermal_model_firmware_issue/
Napsal : 08/03/2026 10:13 pm
heinzight
(@heinzight)
Had the Revo 6 on my MK3S for several months, with beautiful results. Swapped the .4 nozzle for a .25 and began to print. DON'T DO THAT! At least in my case I should have gone through calibrations first as I now have a 'groovy' design on my build plate and it bent the Revo. Ordered and installed new one and powered up. MMU2 spindle revolved but when the head began to move a loud squeely scretch bellowed out. What was that and what could have caused it? (I know, I did post this upper part in Mods but no responses and seems like lots of REVO folks here). I have unplugged every connector (not in Einsy) except motors. Still screetch. It was just a replacement so I didn't have to go into the Einsy. Only the heater & thermistor wires were necessary to change. I let the squeal continue of a few seconds and MAXTEMP appeared on LCD. Then sound stopped. But it's locked, pushing the button does nothing. Powered off and on again. Same squeal but this time error said MINTEMP. Subsequent tries always yielded MAXTEMP. Temps on LCD are both 23 with the nozzel varying from 19 to 26. Prusa chat was no help, E3D didn't know, maybe thermistor? Did I get a faulty REVO replacement?
Napsal : 05/05/2026 12:22 am
