Terminal block connector for extruder heater?
Kody s
(@kody-s)
Does anyone know what size terminal block connector I need for the Einsy Rambo board to connect the extruder heater to it? Bonus points if you have a link for one!
I'd also be interested in any information about using a BL touch with an Einsy board. I havent looked much into this yet so the information could be readily available, but I figured I might as well ask since I was posting this.
If you're wondering why I'm asking these questions, I'm converting my crappy Duplicator I3 to the "ReDuplicator"(Link: https://www.thingiverse.com/thing:2686588/ ). I opted to upgrade pretty much everything so it's really more of a brand new build than a conversion.
Publié : 11/10/2018 12:48 am
Kody s
(@kody-s)
Re: Terminal block connector for extruder heater?
These look pretty close:
https://www.amazon.com/uxcell-20Pcs-KF2EDGK-Terminal-Connector/dp/B06X3XT7WZ/ref=sr_1_10?ie=UTF8&qid=1539211975&sr=8-10&keywords=terminal+block+connector+2+pin
Just want to make sure I order the right ones.
Publié : 11/10/2018 12:55 am
The Plastic Shed
(@the-plastic-shed)
Nah they aren't square. They're more like these
https://www.amazon.co.uk/SODIAL-5-08mm-Pitch-Terminal-Connector/dp/B0747N76HC/ref=sr_1_4?ie=UTF8&qid=1539212777&sr=8-4&keywords=5.08mm+pitch+2+pin+plug-in+screw+pcb
Which are round on one side
Publié : 11/10/2018 1:07 am
