support is too strong
BernieC
(@berniec)
I hope this is the place to ask about prusaslicer....  I have a model with a very delicate part that requires support.   the problem is that the support is stronger than the infill is and I have *not* found a way to get the support free without breaking the part.    I don't understand hardly at all all the fancy settings in prusaslicer but I'm thinking that what I have to do is either make the infill be beefier or the supports wimpier [if there's another way to handle this, do let me know].  I'm a bit loathe to upping the infill because that'll fill up the whole model., not just the delicate part.  So I'm thinking that perhaps a support-tweak might do the job.   Right now, I have infill density at 15%/rectilinear.  And suppoort contact Z distance .25.   What would happen if changed the support distance to, say, .5?  Thanks!
Postato : 11/10/2019 2:25 pm
Utenti
RE: support is too strong
This is a problem I also have.  I have started using Simplify3D for supports because of it.
Postato : 11/10/2019 3:59 pm
You can use modifiers to change the infill in the breaking section.  But then you'll need to up your game on Plicer knowledge.
Postato : 11/10/2019 7:54 pm
BernieC
(@berniec)
@tim-m30
Is there a tutorial or something explaining that?  I use support enforcers all the time but I've never understood what the "modifier"s do.
Postato : 11/10/2019 8:26 pm
Utenti
Plenty on YouTube:
Postato : 11/10/2019 8:29 pm
BernieC
(@berniec)
That's custom supports -- as I mentioned, I'm OK with them.  I'm guessing, though, what you meant is "modifier meshes" -- it seems that they'll let you mess with the infill.   As you said, there are several youtube vids about modifiers [look complicated! :o)] but thanks for letting me know what the right search term is.
Postato : 11/10/2019 8:54 pm
Utenti
Search YouTube and you will find it.
Postato : 11/10/2019 9:02 pm
BernieC
(@berniec)
I did and I'm amazed -- it was easy!!   I saw the 'modifiers' on the context menu of my model but I didn't know exactly what that was about.  I watched a youtube vid and was surprised at how straightforward it was [especially if you already know how to mess with support enforcers].
 I created one and when I right-click on it "infill" is one of the choices -- I left the pattern alone [I have *no* idea how you choose among all the patterns] but there was "infill" 15%  I changed it to 25% and then did the support enforcer [turns out it was the identical size and shape as the modifier, since I want to better-infill *just* those places I'm attaching supports].   I"m printing a test run now and in a few hours I'll know if it worked.  THANKS for the help!!
Postato : 11/10/2019 9:12 pm
