RE: Support Blocker doesn't work ....
You misunderstand how blockers work. They DO NOT stop support going through them. That is not how they function. Both blockers and enforcers work where they intersect with the model. As your lower cylinder sticks out the top of the blocker support is generated there and freely passes through the area to the bed.
If you just put the blocker touching the object all the way to the top then none of the support would be generated, even if the blocker doesnt touch the bed.
Postato : 02/09/2020 10:08 pm
