Super P.I.N.D.A. on Mk3s
MagoT
(@magot)
Hi everyone,
I have installed the new super pinda in my MK3 and everything seems to be working correctly, except that in menu / support / temperatures the sensor always indicates 0 °. I installed firmware 3.9.2 (the latest at the moment). I also tried to run the complete wizard again, without any problem, I also did some test prints and everything seems to work correctly, except that the sensor temp info is always at 0°. Consequently any G-Code M860 command does not respond. Could someone give me info about that?
Best Answer by Baklin:
I'm not sure about the G-code. But the SuperPinda doesn't have a temp sensor anymore. That is why it has 3 wires compared to the older Pinda that had 4 wires.
So the 0 deg should be oke. But any G-code that uses the Pinda temp isn't going to work anymore. (i guess)
Napsal : 03/01/2021 8:58 am
Baklin
(@baklin)
RE: Super P.I.N.D.A. on Mk3s
Napsal : 03/01/2021 9:08 am
1 lidem se líbí
