strange characters around the display
Hedo3D
(@hedo3d)
Hello everybody,
I have been using firmware 3.8.1 for a few days now and everything seems to be going well so far. However, yesterday after switching on and setting a bed temperature over the webinterface (octoprint) to 80 degrees, I had strange characters in the display of the MK3s. I have connected a Raspberry Pi 4 with octoprint version 1.3.12 via the USB connection. Since the display representation could possibly indicate a memory problem, I did want to post this in the forum. After a reset everything worked again and since then it has not happened again.
Has anyone else ever had this issue?
Greetings
Opublikowany : 22/12/2019 3:47 pm
Jonny Menkakow
(@jonny-menkakow)
RE: strange characters around the display
You are not alone. Here are a bit more infos: https://github.com/prusa3d/Prusa-Firmware/issues/2343
Opublikowany : 22/12/2019 6:37 pm
Hedo3D
(@hedo3d)
thanks for the hint 👍
Opublikowany : 26/12/2019 9:42 am
