Squicking noise: failed unwind after filament ended
bgoner
(@bgoner)
Hi, Prusa Gang!
Assembled a prusa a couple of days ago and today I tested running out of filament. Unfortunately it couldn't get it back and had to open the side hatch the get it out.
After this intervention the following squicking sound appeared: https://imgur.com/a/yabWj10
On retraction there is a big squick. Sounds like wet nylon squicking. High frequency squicks sound like a machine gun on the video.
 - I don't think I've damaged the PTU tube.
 - It's not from the bondtech gears
 - Could it be plastic debris in the metal ball compartment? (full disassembly 🙁  )
On the video Josef Prusa shows he cuts a fillament and end is straight. But in my case the end had like 90 degrees so that they could begin winding the spool.
Thanks!
Ce sujet a été modifié il y a 6 years 2 fois par bgoner
Publié : 03/01/2020 10:54 am
bgoner
(@bgoner)
RE: Squicking noise: failed unwind after filament ended
When I push the filament on the right, which is the direction that loosens the metal ball, the noise decreases or disappears. That's why I'm asking about it.
Publié : 03/01/2020 11:03 am
bgoner
(@bgoner)
I think I've fixed it:
1. remove top cover and remove filament sensor
2. push filament and catch the filament lever with something and open it as much as you can so that the ball has a much space as possible
3. remove the filament
4. blow compressed air through the filament entry hole
no more deadly squickidy-squick
Publié : 04/01/2020 8:10 pm
bgoner
(@bgoner)
Unfortunately it's back quite fast.
Is this normal when a lot of retraction is used?
Publié : 06/01/2020 5:53 pm
