Squicking noise: failed unwind after filament ended
bgoner
(@bgoner)
Hi, Prusa Gang!
Assembled a prusa a couple of days ago and today I tested running out of filament. Unfortunately it couldn't get it back and had to open the side hatch the get it out.
After this intervention the following squicking sound appeared: https://imgur.com/a/yabWj10
On retraction there is a big squick. Sounds like wet nylon squicking. High frequency squicks sound like a machine gun on the video.
 - I don't think I've damaged the PTU tube.
 - It's not from the bondtech gears
 - Could it be plastic debris in the metal ball compartment? (full disassembly 🙁  )
On the video Josef Prusa shows he cuts a fillament and end is straight. But in my case the end had like 90 degrees so that they could begin winding the spool.
Thanks!
Este debate ha sido modificado el hace 6 years 2 veces por bgoner
Respondido : 03/01/2020 10:54 am
bgoner
(@bgoner)
RE: Squicking noise: failed unwind after filament ended
When I push the filament on the right, which is the direction that loosens the metal ball, the noise decreases or disappears. That's why I'm asking about it.
Respondido : 03/01/2020 11:03 am
bgoner
(@bgoner)
I think I've fixed it:
1. remove top cover and remove filament sensor
2. push filament and catch the filament lever with something and open it as much as you can so that the ball has a much space as possible
3. remove the filament
4. blow compressed air through the filament entry hole
no more deadly squickidy-squick
Respondido : 04/01/2020 8:10 pm
bgoner
(@bgoner)
Unfortunately it's back quite fast.
Is this normal when a lot of retraction is used?
Respondido : 06/01/2020 5:53 pm
