Squeaking while printing
paulmaunders
(@paulmaunders)
Mitglied
Recently my mk3s has started squeaking while printing. I'm not exactly sure where it is coming from, but I think it could possibly be the filament entering the extruder.
IMG_3277
Does anyone know how to prevent this?
While writing this post, I tried pushing the filament further into the extruder as it was printing and it seems to have stopped the noise for the moment.
Veröffentlicht : 02/07/2023 7:25 pm
Hello
(@hello)
RE: Squeaking while printing
Open the idler door on the extruder the check the gear are allined
Veröffentlicht : 02/07/2023 7:57 pm
Begin by working through https://help.prusa3d.com/en/article/i3-printers-regular-maintenance_2072
Come back if the problem persists.
Veröffentlicht : 03/07/2023 4:13 am
Printerman
(@printerman-3)
I have the same problem, when printing PETG the extruder squeaks every time it retracts. It sounds like two PET water bottles being pushed together. It doesn't affect printing though. I will follow the guide above and see if it helps!
Veröffentlicht : 05/07/2023 5:12 pm
Printerman
(@printerman-3)
I  found the problem! there was filament dust in the run-out sensor that made the noise(the filament had a hard time passing). I got most of it out, so im back printing again but i will half to disassemble it and give it a thorough clean.
Veröffentlicht : 05/07/2023 7:46 pm
Printerman
(@printerman-3)
I dont know how it got there, but the filament sensor hole was filled with plastic. During the night it jammed and the print failed half way, i had to disassembel it to get it all out of there.
Veröffentlicht : 06/07/2023 2:34 pm
