Spring Steel Sheet top plate broke
tegmento
(@tegmento)
hi im using standart Spring Steel Sheet 1,5 year with any problem. but today when remoing printed tpu part on the bed top surface has been removed 🙁 it is normal ? i wasnt use any adhesive ( glue ,hair spray or anything )
do you have any advise repair or using tips.thank you
Best Answer by Diem:
https://help.prusa3d.com/en/guide/replacing-the-pei-sheet-on-the-mk3s-mk3-mk2-5s-mk2-5_23920
But use the other side until that wears out too.
Postato : 05/11/2021 3:08 pm
RE: Spring Steel Sheet top plate broke
Postato : 05/11/2021 6:42 pm
1 persone hanno apprezzato
tegmento
(@tegmento)
Thank you for your great advise 🙂
Postato : 05/11/2021 6:50 pm
Utenti
Heck, you can still use that side if you watch where it is printing.
Postato : 05/11/2021 6:55 pm
tegmento
(@tegmento)
Yes of course. i close the crack with masking tape prevent corosion and continue using until unprintable surface 🙂
Postato : 05/11/2021 7:35 pm
Utenti
Blue masking tape is amazing.
Postato : 07/11/2021 3:24 pm
