Spring Steel Sheet top plate broke
hi im using standart Spring Steel Sheet 1,5 year with any problem. but today when remoing printed tpu part on the bed top surface has been removed 🙁 it is normal ? i wasnt use any adhesive ( glue ,hair spray or anything )
do you have any advise repair or using tips.thank you
Best Answer by Diem:
https://help.prusa3d.com/en/guide/replacing-the-pei-sheet-on-the-mk3s-mk3-mk2-5s-mk2-5_23920
But use the other side until that wears out too.
RE: Spring Steel Sheet top plate broke
Thank you for your great advise 🙂
Heck, you can still use that side if you watch where it is printing.
Yes of course. i close the crack with masking tape prevent corosion and continue using until unprintable surface 🙂
Blue masking tape is amazing.
