Spring Steel Plate
K6GHL
(@k6ghl)
Spring Steel Plate
Noob here.  Not sure if this is the right place to ask this.  I just got a new textured spring steel plate.  Up to now I have only used the smooth plate that came with my Mk3S+.  My question is do I just need to adjust my z height for the new plate or is there a way to save the setting in memory and I then select what plate I'm using.  I look in Prusa Slicer and did not see where I could do this.
Opublikowany : 19/03/2022 4:45 pm
ARU
 ARU
(@aru)
RE: Spring Steel Plate
You need indeed to calibrate the Z height after having selected this type of plate in the printer interface. One click on the Button and 4th line called sheet
Opublikowany : 19/03/2022 4:52 pm
Yes, they will be of different thickness.
LCD menu > Settings > Steel Sheets
Opublikowany : 19/03/2022 4:55 pm
Chicago Keri polubić
