Spring Steel Plate
Noob here. Not sure if this is the right place to ask this. I just got a new textured spring steel plate. Up to now I have only used the smooth plate that came with my Mk3S+. My question is do I just need to adjust my z height for the new plate or is there a way to save the setting in memory and I then select what plate I'm using. I look in Prusa Slicer and did not see where I could do this.
Veröffentlicht : 19/03/2022 4:45 pm
RE: Spring Steel Plate
You need indeed to calibrate the Z height after having selected this type of plate in the printer interface. One click on the Button and 4th line called sheet
Veröffentlicht : 19/03/2022 4:52 pm
Yes, they will be of different thickness.
LCD menu > Settings > Steel Sheets
Veröffentlicht : 19/03/2022 4:55 pm
