Specs for "Hotend thermistor E3D"
P. Larsen
(@p-larsen)
I am looking to replace the original hotend and as we've all gotten used to (ha) everything is out of stock and nobody knows (or will tell) when it's back in stock.  I'm looking for the specs of the thermistor used with the MK3* - https://www.prusa3d.com/product/hotend-thermistor-e3d/ is what I'm looking to replace.
I have a few spares for another printer that I would like to ensure are of the right spec. But I cannot see the spec on the Prusa3d site - so for now I'm assuming it's the same as the original e3d found here: https://e3d-online.com/products/thermistor-cartridge and here: https://www.matterhackers.com/store/printer-accessories/e3d-thermistor-cartridge .
I'm about 99.9% sure that what I have will not work because I have a very small sensor at the end, instead of a tube that can be locked inside of the heating block. My other printer uses heating elements where you attach the sensor in a small indent and use an external screw to lock the cable in (not the thermostat).   Does prusa use the standard E3D components or have they customized more than just the cable?
Respondido : 17/01/2023 2:46 am
