some problem encountered z leveling enforced error is back. - The Lightbar it had been!
TheSlowPrinter
(@theslowprinter-2)
First, it's about an Fysetc MK3s clone, not the original. But anyway, as the original very likely will suffer from the same issue, I want to report it somewhere to help to avoid some's else the same trouble!
I wanted to see a bit more at my printer. Hence, I printed, built and mounted this light found on Etsy
The files can be found on prusaprinters as well. I used the files from the Dual Mount - Z-Axis Top version if I am not mistaken.
After struggling with the some problem encountered z leveling enforced error is back. error for some days trying to disassemble, clean, lube and reassemble the z axis thinking a stuck trapezoid nut had been the problem (actually it turned, but thought it could be easier), I stumbled over a YouTube video showing the actual problem!
At Z leveling, the X carriage was limited by the light mount (which replaces the Z axis orange top parts) and screws up the Z leveling later on!
Actually the two M3 screws atop of the trapezoid nuts are touching the light bar too early. They need a little more space obviously.
Removing the light and mounting the original holders everything worked fine again!
I hope he will redesign the thing not causing issues anymore.
Despite that, the light is really an improvement for the printer!
Veröffentlicht : 21/02/2023 11:23 am
TheSlowPrinter
(@theslowprinter-2)
IT WASN'T THE LIGHT BAR, but not proper seating of the Y axis rods in the holders.
After some days of successful prints, the error returned again. I had to hunt down the error further and figured out the Y axis rods had been not sitting perfectly in the holders.
Sorry for the wrong accusations / suspicions. It was a coincident disassembling the light solved the issues.
Veröffentlicht : 02/04/2023 1:19 pm
TheSlowPrinter
(@theslowprinter-2)
RE: some problem encountered z leveling enforced error is back. - The Lightbar it had been!
Oh I love it, when I have a problem with it's solution documented!
This time it happened on my original MK3s, reading the solution I realized the cable tie holding the Y rod broke!
New cable tie and everything up and running again!
No idea, whether I would have seen it without the hint...
Veröffentlicht : 25/10/2023 10:01 am
