[SOLVED] Layers not aligning on Y
Winthorp
(@winthorp)
Hi all,
I've recently bought an Original Prusa MK3 kit, it's my second kit printer and I just finished assembling it.
The printer autotest ran without problems giving all OK, the first layer calibration also ran flawlessy.
But when I started my first prints I've noticed there is an align problem on the Y plane
The one on the right is with Crash Sensor turned ON (you can see the Y slide on the bottom part below PRUSA), the second one is in Stealth mode, so without Crash Sensor and it has those zigzags at the bottom (still Y slide)
On this side image the Y slide is more evident
I'm running on the last Firmware, I tried both Slic3r PE and Simplify3D and they get the same error
I checked the Y belt tension and they look ok with the pulleys free to move
I'm using the magnetic steel plate
Any ideas?
(more photo of a simply round object)
Thank you,
Robert
Postato : 08/08/2018 6:55 pm
Kazibole
(@kazibole)
Re: Layers not aligning on Y
Loose belt, loose grub screw on motor pulley, u bolt too loose or tight.
Postato : 08/08/2018 7:14 pm
Winthorp
(@winthorp)
The belt look ok, not too lose not too stiff, the grub screw is firmly on the motor, what puzzles me is that the problem appears around 2-3 layers and then disappeat 😮
Postato : 08/08/2018 9:27 pm
Winthorp
(@winthorp)
Today I had the time to run a close inspection to the printer
Turns out it was really a slightly loose grub screw, coudn't see it at first glance :mrgreen:
Postato : 09/08/2018 5:54 pm
