[Résolu] Smooth PEI sheet adhension after cleaning with acetone
devvrider
(@devvrider)
Hi, I have a couple of smooth PEI sheets that has been used for a while (2 years). Recently I have some adhesion problems with them.
I tried cleaning them with acetone (nail polish remover) , but it seems doesnt help much.
I also have a couple of new smooth PEI sheets that has great bed adhesion on the same printer, so I guess it's not the print settings of the printer.
The old PEI sheets has no problem if I apply glue stock on them.
Are these old PEI sheets non "refurbish-able" anymore? So I have to apply glue stick every time from now on?
Thanks.
Publié : 14/07/2022 2:27 pm
JustMe3D
(@justme3d)
RE: Smooth PEI sheet adhension after cleaning with acetone
Acetone is a great idea for killing the sheets dead (and yes I´ve seen recommendations several years old to use acetone once in a while, which I believe are not supported anymore...).
Take a dish sponge, non-regreasing dish soap, hot water and SCRUB the dirt of the sheet. Non-regreasing means no additives like "hand-friendly", "gentle skin" or other stuff, just plain dish soap. Then dry the sheet with kitchen paper (again without any stupid ingredients, just plain kitchen paper)by rubbing it vigorously.
Then your prints should work without adhesives (to the extent the respective material generally works with the respective sheet without adhesives).
Print and enjoy.
Publié : 14/07/2022 3:02 pm
AnnieR
(@annier)
Hairspray! Got2beGlued, get it anywhere. Works like a champ.
Publié : 16/07/2022 4:01 pm
hawai
(@hawai)
Although I agree with @JustMe3D that acetone is not necessarily a smart idea, are you sure you used an acetone based nail polish remover? Nowadays a lot of them are using ethyl-acetate as solvent.
Which should be removing PLA residue but IIRC PETG, ASB and ASA are resistant to it.
Publié : 19/07/2022 6:21 am
jsw
 jsw
(@jsw)
I would be concerned that the commercial nail polish remover, even if it is acetone-based, has ingredients other than the basic solvent(s), such as baby oil, lanolin, fragrances, etc.
Some of the acetone substitutes (various alkyl acetates, etc.) may indeed be good solvents but things such as lanolin, baby oil (mineral oil, castor oil, various other oils) are greasy and oily and will tend to discourage adhesion.
In the States, acetone by itself can be obtained at most hardware stores and paint stores. Some larger drug stores will carry clinical grade acetone as well.
I can assure you that the occasional wipe-off of the smooth PEI plate with straight acetone will not damage it, and will at least somewhat improve the ability of filament to stick to it.  Just don't make a habit out of doing it daily or anything.  Use in moderation.
TFM says not to use acetone on the textured build plate, but there have been occasional reports here that it has been done (in moderation) without the world coming to a screeching halt.  I would be very leery of using acetone on the satin build plate.
Publié : 19/07/2022 8:26 am
1 personnes ont aimé
towlerg
(@towlerg)
The jury is still out on this one but there's an argument that suggests the chemical cleaning simply moves contaminants around. I guess you can mitigate this by wiping in known directions (perhaps left to right and front to back)
Publié : 19/07/2022 2:56 pm
jsw
 jsw
(@jsw)
We are going to have to agree to disagree as to what method is truly better, water-based solvents, or organic solvents.
I say that what really matters is that the build plate is truly clean of contamination, far more than what's used to clean it.
Some insist, often very defensively, that "clean your plate and clean it my way" is the universal fix for every issue of getting prints to stick.  It's almost a religion!
I say that what works better for me, might not be what works better for you, and if you have good results doing it your way, all the better.
I have rarely use dish detergent on my build plates.  Why?  I don't have a sink convenient to where the printers are located.  I use alcohol, and lately, what's called denatured alcohol, as isopropyl was difficult to get during the height of the pandemic, so I have it on hand.
I have very few failed prints.  I must be doing something right.  That works for me.  It may or may not work for anyone else.
(Yes, I know, 'But my way is better because ...')  😉
Publié : 19/07/2022 3:11 pm
JustMe3D
(@justme3d)
Posted by: @jsw
One may need DAWN to see the light <rofl>
Publié : 19/07/2022 4:52 pm
devvrider
(@devvrider)
Thanks for the info folks.
I do think the nail polish contains cosmetics that smooths the plates, so it's actually reducing the adhesion.
I gone through the manual again so finally what I did was using a 1000 grit sand paper and sanded the surface with water. The plates were revived 🙂
Publié : 22/07/2022 12:22 pm
Robin
(@robin)
I agree with jsw, but not to disagree. If it works for you, fine, if it does not, find the problem. The problem frequently is, that people say, they use acetone and after a few posts, they find out, that aceton is not the same as nail polish remover. Same with IPA from the drug store. If you want IPA buy IPA, you get 99,9 pure IPA on the internet, same goes for acetone. If you buy soap, buy one that is supposed to remove grease, not make your skin feel better…
After all you need to get the plate clean, how you achieve that is up to you…
Last but not least, as jsw, I never used soap and water, only IPA and rarely acetone and have very few failed printer as well…
Publié : 22/07/2022 2:18 pm
TheReverend
(@thereverend)
Toothpaste works really well to remove old glue stick residue. Dab of paste, splash of water, rub it in, rinse it thoroughly. A drop off regular dawn will take care of any residue if your brand leaves any.
For hard to stick prints, I use Vision Miner Nano Adhesive. For prints that stick too hard I use glue stick, or painters tape.
I switched to the textured pei sheets, and definitely prefer them to the smooth.
Publié : 21/04/2023 5:39 am
Thejiral
(@thejiral)
Posted by: @justme3d
Print and enjoy.
This is the standard advice but with older PEI sheet, a certain loss of adhesion even with well washed plates isn't mere myth but a real possibility. No amount of dish soap washing will restore that. The current consensus in that case seems to be to roughen the PEI sheet up just as much as needed (and not more), with the green side of sponge for example. Acetone can do something similar. In both cases these are aggressive methods and might damage the plate.
The one alternative to all of that is to use adhesives. I think Kores is not very convenient to use and also helps only to a point. I personally use dimafix sticks, easy to apply, easy to wash off by simply rinsing it shortly with water. Magigoo is also a good option but there are various other adhesives. I am using those with a plate which showed exactly the same deterioration after around 2 years of use, never had any adhesion problem with it ever since and so I am not even using the replacement sheet I purchased (and which had great adhesion again, even without adhisve). Plus with adhesive one does not have to be paranoid about cleanliness of the plate either and can skip the IPA wiping altogether. And in most cases with adhesive, you do not need to use brims even with challenging models either. That robustness of the process, peace of mind and getting rid of brims was what made me change sides on this issue.
Ce message a été modifié il y a 3 years 3 fois par Thejiral
Publié : 21/04/2023 7:41 am
jsw
 jsw
(@jsw)
The Party Line has always been to use acetone only occasionally and sparingly to clean and 'refresh' the smooth PEI build plate, only when needed.
The Party Line is also to NEVER use acetone on the Prusa textured build plate under any circumstances.
Over the years, I've indeed found that an occasional cleaning with acetone will indeed restore some of the sticking ability to a well-used smooth PEI build plate.  I've never observed any decrease in sticking ability from doing so.
Publié : 21/04/2023 10:53 am
BuzzBazz
(@buzzbazz)
Membre
I have to ask as I am a little confused. Hi, second had owner of a MK2.5S+ here, and I was having massive problems with bed adhesion when using IPA.
It's a brand called Blåtind here (Norway), so I'm not sure it's proper, but it should be as it's sold as that. There should be no contaminants or other things in it, but I kept having bad first layer adhesion.
Scoured the web and found the old tricks with fine grit sand paper (had 5000, 5K so had to buy new lower grit, 4/6 and 800), properly washing the plate with soap and lukewarm water, and while all this did kind of help, there is tons of fine concrete dust in our apartment, and after a few days of not running I would have to wipe the plate down with IPA to clean it.
I use these round cotton makeup pads, they have nothing on them, and while I try to remember to wash my hands to avoid extra grease getting on the plates, it would get worse over time.
Like really bad. The more I used IPA, the less clean the plates felt. Washing them with soap again helped more than IPA, and I use that IPA for all other electronics repairs with no problems.
So I tried acetone. And it was like night and day.
Now I don't understand why it would be standard procedure to not use it when it works this well. Been going strong for almost 2 years now with just acetone on a pad or two, wipe in a grid pattern to not have too much on the plate, and aside from dust, most of the time the come out looking clean, but the prints stick to the smooth PEI.
Looking into getting more types of plates with different patterns and stuff, I keep seeing "No Acetone" so I thought I should ask because I have no plans on using anything else when it clearly does not damage the plates, and keeps them clean for when I need to print. Having said that, I do not wipe them warm, I only do the wipe when the plates are cold, before printing. And for that day ish I won't need glue or adhesive. I just haven't tried too much with the fancy plates I have because of lifting, but there are so many types now I'm going crazy. There is PEI, PEY, PEG, PEO & PET, all with different patterns, and then there is H1Y & H1H through H8H, but no H4H? Again patterns, but aside from some temperature differences in PEY being 30-90C, PEO & PET being 50-120C, PEI being up to 300C, everything else is kind of hidden. I like the patterns, but if I can't print on them because the filament is to warm so it ruins them they become worthless, and even more if I can't clean them properly with Soap, IPA or even Acetone it becomes that much harder to select and buy.
Are we stuck with using glue or sound crazy because we are the weird old farts using Acetone?
No idea what I'm doing, Mensa brain running Copycat from COD.
FFFinderV1(dead)/Secondhand MK2.5S+(limbo, burnt bed pins)/P1S Combo(in transit)
Publié : 30/12/2024 8:20 am
BuzzBazz
(@buzzbazz)
Membre
Addition* Found H4H plates, and TK99 PEI plates. I'm so confused.
Publié : 31/12/2024 1:01 pm
