Small stops "Heating" with firmware 3.7.1
Jeremy
(@jeremy)
Since i upgraded to last 3.7.1 firmware, printer MK3 make small stops of about 3 seconds, and LCD says "heating".
Temperatures seems fines on LCD (like 215/215 and 55/55).
I did not have this before upgrade.
Problem is that hotend stops on the object while waiting 3 seconds, it does not go up, and it leaves blobs on the print.
Opublikowany : 03/06/2019 1:14 pm
vintagepc
(@vintagepc)
RE: Small stops "Heating" with firmware 3.7.1
Disable your filament sensor. It's registering false runouts that then get re-checked and are not really runouts.
https://github.com/prusa3d/Prusa-Firmware/issues/1522
Opublikowany : 03/06/2019 1:41 pm
Jeremy
(@jeremy)
Thanks, i'm having a try, it seems OK with filament sensor OFF.
Opublikowany : 03/06/2019 3:42 pm
vintagepc polubić
Bastlerinny
(@bastlerinny)
Hi, having the same problem - didn't try out the filament sensor "fix" yet. Will report later.
However, bigger issue is: does anyone know whether this firmware issue has been resolved - or whether this has at least been acknowledged? (I haven't seen any notion of this).
Opublikowany : 11/08/2020 5:14 pm
