Slic3rPE Question
Pepe LePew
(@pepe-lepew)
Slic3rPE Question
Hi
1st: is there a specific thread dedicated to questions on either the stable or Beta releases?
Hate just popping stuff out in the event there is a certain area. 🙂
Maybe a dumb question but....
2: On the Print Settings tab under Speed...On certain settings for example Smaller Perimeters or Solid Infill
it shows MM/s or %
Am I to assume that if I leave it at for example 25 it reflects MMs or if I change it to 25% it reflects %
I do not see any defined settings within the program so if the above is incorrect what dictates MM/s or %?
I have been using the presets mostly since I got my Kit built but want to dive into the settings
and this so far is the only one I need clarification on.
Thanks
Veröffentlicht : 02/04/2019 9:11 pm
holmes4
(@holmes4)
Re: Slic3rPE Question
Yes, you have it right, If you add %, that's what it uses.
Veröffentlicht : 02/04/2019 9:36 pm
Pepe LePew
(@pepe-lepew)
@holmes4
Awesome thank you
Veröffentlicht : 02/04/2019 9:38 pm
