slic3rpe: is it possible to "trim" an stl file?
BernieC
(@berniec)
I have an STL file that is too large.   Is it possible to "crop" an STL file?    I'm half thinking that I could kinda do it by rotating the stl 90 degrees [and so now x, or y, is "up"] and then use the "cut" function four times to crop the four edges.... but... is there a less klunky way?
/Bernie\
Opublikowany : 30/04/2019 2:10 am
Vojtěch
(@vojtech)
RE: slic3rpe: is it possible to "trim" an stl file?
In Slic3r-PE, that's the only way to go. Obviously, other tools can do more. Eg. in openSCAD you simply import your STL and do an intersection with a cube.
Opublikowany : 30/04/2019 6:19 am
1 ludzie polubili
