Slic3r PE settings issues
CosmicVelocity
(@cosmicvelocity)
I'm not sure if I'm the only one with the problem:
Under Filament settings I enter my (calibrated) extrusion multiplier, sasy 1,03 and a filament price, say 23,99€.
I saved the settings and went on printing.
The nest time I looked (reloaded the above template on another day) those settings were crippled to whole integers: extrusion multiplier to "1" and filament price to "23". At least for the price I can confirm that the crippled value is being used for cost calculation when exporting gcode.
I did not find the time yet to check if the extrusion multiplier is internally reset to 1 or if the value just gets clipped on the page displaying it.
Slic3r PE 1,41,1+win64, Win10 Home (always most recent updates)
Thanks for checking.
-Prusa i3 MK3 single extruder (kit) as intended by author
-Creality CR-10 modded beyond recognizabilitty 😀 Constantly sleep-deprived. General wisecrack of the benign kind. Knows he knows nothing.
Respondido : 04/02/2019 10:06 am
Re: Slic3r PE settings issues
If you are typing it into SlicerPE like you are into the forum then its not surprising it wont remember it.
If you type "1.05" it will save it. If you type "1,05" it wont. You need to use a decimal point and not a comma to separate the numbers.
I've just tried it on mine and typing in your way results in the number being truncated as you describe.
Respondido : 04/02/2019 4:52 pm
CosmicVelocity
(@cosmicvelocity)
Thanks for the revelation and sorry for being german 😆
...after roughly 45 years in electronis and coding, I finally got overrun by senile stubbornness :facepalm:
Respondido : 04/02/2019 10:32 pm
