Slic3r PE: Printer, filament and other settings not preloaded?
Wilko
(@wilko)
I assembled my i3 Mk3S and installed the latest software from the site, including Slic3r PE.
When I look at the Slic3r PE instruction videos, there are a long list of printer and filament choices.
In my installed version of Slic3r PE there is just ---system presets --- and ----user presets----.
I looked through a couple of pages of this particular forum and did a slic3r PE search here on the forum, but I don't come across the same issue.
Am I doing something wrong or am I missing something obvious?
Should I download the .ini files or other configuration files somewhere else?
Prusa MK3S
Prusa SL1
Prusa CW1
Anet ET5 pro
Anycubic Mono X
Opublikowany : 09/04/2019 4:17 pm
Zach
 Zach
(@zach-3)
Re: Slic3r PE: Printer, filament and other settings not preloaded?
When you turn Slic3r PE on for the first time it should run you through a configuration wizard that asks what printer you have. Obviously you should pick the MK3S (0.4mm nozzle).
This guide may help:
https://www.prusaprinters.org/slic3r-prusa-edition-beginners-guide/
Opublikowany : 09/04/2019 4:24 pm
Try opening the Configuration menu and going through the Configuration assistant... wizard. Select the appropriate printer and nozzle size options. You should have a bunch of stuff under --- system presets --- afterwards.
Opublikowany : 09/04/2019 4:25 pm
dclaar
(@dclaar)
Thanks for this! I saw "EVERYTHING ABOUT NOZZLES WITH A DIFFERENT DIAMETER") on prusaprinters.org, which claims that .25 and .6 profiles are pre-loaded. Maybe I just didn't notice that I could pick the other nozzle sizes the first time, since I didn't have any other sizes at the time, but having to tick boxes isn't really "pre-loaded". 🙂 So I was desperately to find them, and this post pointed the way: After re-running configuration and ticking the .6 box, I have the settings I was looking for.
Opublikowany : 20/04/2019 11:48 pm
