Slic3r PE does not save new Print Settings
stonefred
(@stonefred)
I have created a new User Preset for the Printer Settings for my 0.8 mm nozzle. Switching to this new preset removes all presets in Print Settings. I created a new preset by copying the values from a preset from the 0.6 mm nozzle settings. When I save the new Print Settings preset, the following happens:
  • No matter what name I enter in the dialog "Save preset", the result is always called "0.05mm ULTRADETAIL".
  • The preset is then listed as a System Preset, marked by a red flag.
  • If I make changes to the preset and save again, it is then saved with the correct name as a User Preset.
  • The System Preset called "0.05mm ULTRADETAIL" is gone.
  • After restarting Slic3r PE, the User Preset is gone as well.
  • The exported G-Code is complete garbage. Speed settings are all set to the lowest value and all other parameters seem to default to Slic3r PE's default settings.
  • I can't seem to find the functionality to copy Print Settings presets from one Printer Settings preset to another.
    I am using Slic3r PE version 1.41.0+ win64
    Publié : 02/11/2018 6:28 pm
    Re: Slic3r PE does not save new Print Settings
    Just give it a new name when saving. Think of it as "save as" when the original is read-only.
    Step 1: Load an existing profile and modify paramters. Here I've loaded the Prusa-provided 0.60mm nozzle profile and changed the Nozzle diameter:
    Step 2: Save profile with an appropriate new name:
    Step 3: Verify new profile is available.
    You'll need to do the same thing for every Printer Settings, Filament Settings and Print Settings profile you modify.
    Publié : 02/11/2018 7:14 pm
    stonefred
    (@stonefred)
    Thanks for the detailed description, but it's exactly what I already did. The problem is, none if it works. As soon as I save a new Print Setting preset, the following happens:
  • Publié : 03/11/2018 12:57 pm
    stonefred
    (@stonefred)
    Still not working. I tried reinstalling and setting folder permissions as well. It seems like Slic3r just cannot save new Print Setting presets in a new Printer Setting preset on my PC.
    However, I found your Slic3r profiles for the MK3 and they are working great!
    Reference: http://projects.ttlexceeded.com/3dprinting_slic3r_sample_profiles.html
    Publié : 04/11/2018 10:28 pm
    jackson.w
    (@jackson-w)
    Going to bump this thread.
    Since updating i'm getting the same issue. Anyone find a fix yet?
    Publié : 15/11/2018 8:39 pm
    sudden.i
    (@sudden-i)
    Hi, me noob here with same issue. But plz see https://github.com/prusa3d/Slic3r/issues/1066 with subject Buggy "Print Settings" behavior when changing "Printer Settings" nozzle size for an explanation. I hope the issue will be re-opened in Githbub.
    Publié : 30/11/2018 3:23 pm
    Cory
     Cory
    (@cory)
    Am I taking crazy pills?!?!?
    This issue is happening to me too. How has this post been ignored for over a year and no one is responding to it with a fix? Is everyone in the world not saving their print settings like the software claims to make possible?????????
    Publié : 17/03/2019 9:24 pm
    jwvaughn
    (@jwvaughn)
    Since I don’t see it mentioned I’m assuming Windows 10. I am running Win 10 Pro X64 just in case that might make a difference.
    I have saved all three tabs as user setting with no problems with both Slic3R PE and that Alpha 7 version. They all load correctly and the system defaults are all available. The only difference between the production and alpha versions is that they get saved to different folders:
    Production version - C:\Users\<User Name>\AppData\Roaming\Slic3rPE
    Alpha test version - C:\Users\<User Name>\AppData\Roaming\Slic3rPE-alpha
    The following subdirectories exist under both with my user settings
    filament
    print
    printer
    I’m wondering if you are having problems creating subdirectories for some reason? Perhaps a permission issue?
    Publié : 18/03/2019 1:13 am
    Matt Carter
    (@matt-carter)
    Hey,
    Ok so I was having the same issue when I changed nozzle diameter in 'Printer Settings'
    The reason is that the list of 'Print Settings' that you are given is all those that have the dependancy set for the nozzle diameter that is currently set in the 'Printer Settings'.
    If you change your nozzle diameter back to 0.4 the default list will reappear.
    The solution is while it is set to 0.4 open your custom 'Print Settings' profile that you want to use with a different nozzle, and in the 'Dependancies' section change the line:
    printer_notes=~/.*PRINTER_VENDOR_PRUSA3D.*/ and printer_notes=~/.*PRINTER_MODEL_MK3.*/ and nozzle_diameter[0]==0.4
    to printer_notes=~/.*PRINTER_VENDOR_PRUSA3D.*/ and printer_notes=~/.*PRINTER_MODEL_MK3.*/ and nozzle_diameter[0]==0.8
    Then when you change back to the 'Printer Settings' with a 0.8mm nozzle diameter, your custom 'Print Settings' will be the only one in the list.
    Regards Matt
    Publié : 19/03/2019 8:08 pm
    Yes, please see the green box on this page. I've tried to explain the issue and show work-arounds. Let me know if you have any questions. It's not a bug, it's a feature. Just a non-obvious one! 😀
    Publié : 19/03/2019 9:02 pm
