Slic3r PE 1.40 won't open
Lamoot
(@lamoot)
Hello, i was using Slic3r PE 1.39.X and it wouldn't open on my PC today, even though it used to work fine. I just updated it to 1.40 and it still won't open. I usually use S3D anyway, but i'd like to get Slic3r working again just in case. Anyone have any idea what's going on?
Veröffentlicht : 26/06/2018 5:56 am
Lamoot
(@lamoot)
Re: Slic3r PE 1.40 won't open
I've uninstalled and reinstalled twice now. Anyone have any idea what could be causing this? Or is anyone else experiencing the same issue?
Veröffentlicht : 27/06/2018 5:31 pm
gkol
 gkol
(@gkol)
Manually remove folder that contains slice3r profile/config. files. After that silc3r will turn on normally - you will just have to go through the wizard.
Config folder can be found at AppData/Roaming/Slic3r or in Documents of "Public" windows profile.
Veröffentlicht : 27/06/2018 8:55 pm
Lamoot
(@lamoot)
Thanks for your reply, I don't have anything in the roaming folder for Slic3r. In the public documents folder, I have a few different files in the Slic3r directory, Objects 210, Objects 214, Samples, Slic3r settings MK3 210, Slic3r settings MK3 214. Are any of those the files you're talking about?
Veröffentlicht : 28/06/2018 7:22 pm
Amaralbl
(@amaralbl)
That solved my problem. I have reinstalled it several times before trying this and it didn't change a thing.
Veröffentlicht : 19/09/2018 1:38 am
kenwolfe
(@kenwolfe)
I don’t have anything like that here. Been pretty frustrated since the Win10 update that I didn’t ask for broke Slic3r.
Anybody else have a similar problem?
Veröffentlicht : 18/11/2018 2:29 am
tracernz
(@tracernz)
Try running it in a terminal emulator (cmd is the closest thing on Windows). It may print something to stderr before dying. On Windows: go to the directory with slic3r.exe in explorer, type cmd into the address bar, hit enter, type slic3r.exe in the prompt, hit enter, see if any output appears.
Veröffentlicht : 19/11/2018 9:02 am
keny.b
(@keny-b)
Hi
i have same error , in cmd isnt nothing output appears,only jump to next line.
result done :
delete: C:>Users>YOURUSERNAME>AppData>Roaming>Slic3r
Veröffentlicht : 20/12/2018 9:03 am
