Slic3r PE 1.40 won't open
Hello, i was using Slic3r PE 1.39.X and it wouldn't open on my PC today, even though it used to work fine. I just updated it to 1.40 and it still won't open. I usually use S3D anyway, but i'd like to get Slic3r working again just in case. Anyone have any idea what's going on?
Re: Slic3r PE 1.40 won't open
I've uninstalled and reinstalled twice now. Anyone have any idea what could be causing this? Or is anyone else experiencing the same issue?
Manually remove folder that contains slice3r profile/config. files. After that silc3r will turn on normally - you will just have to go through the wizard.
Config folder can be found at AppData/Roaming/Slic3r or in Documents of "Public" windows profile.
Thanks for your reply, I don't have anything in the roaming folder for Slic3r. In the public documents folder, I have a few different files in the Slic3r directory, Objects 210, Objects 214, Samples, Slic3r settings MK3 210, Slic3r settings MK3 214. Are any of those the files you're talking about?
That solved my problem. I have reinstalled it several times before trying this and it didn't change a thing.
I don’t have anything like that here. Been pretty frustrated since the Win10 update that I didn’t ask for broke Slic3r.
Anybody else have a similar problem?
Try running it in a terminal emulator (cmd is the closest thing on Windows). It may print something to stderr before dying. On Windows: go to the directory with slic3r.exe in explorer, type cmd into the address bar, hit enter, type slic3r.exe in the prompt, hit enter, see if any output appears.
Hi
i have same error , in cmd isnt nothing output appears,only jump to next line.
result done :
delete: C:>Users>YOURUSERNAME>AppData>Roaming>Slic3r
