Slic3r PE 1.42.02 - soluble interface is not just an interface?!
[Rozwiązany] Slic3r PE 1.42.02 - soluble interface is not just an interface?!
Kryssie
(@kryssie)
I've been trying to slice a model in Slic3rPE to print with filament 1 as the model and support, and filament 2 as BVOH soluble interface.  Problem: the BVOH is incorporated into the support structure in places other than interface, meaning the print uses more (expensive) BVOH than at all necessary.
Does anyone know why this is? Ia it a bug in 1.42.02, or are there settings somewhere I need to change?
Fairfarren
This topic was modified 7 years temu 3 times by Kryssie
Fair farren
Opublikowany : 25/04/2019 12:22 am
Kryssie
(@kryssie)
RE: Slic3r PE 1.42.02 - soluble interface is not just an interface?!
I tried to upload a screenshot of this issue, but this new forum doesn't make it easy.  If you want a pic, tell me how to upload it 🙂
Fair farren
Opublikowany : 25/04/2019 12:30 am
Kryssie
(@kryssie)
This same thing also happens in Slic3R PE 1.42.0-beta too.  Wtf?
Fair farren
Opublikowany : 25/04/2019 12:42 am
Kryssie
(@kryssie)
I found the solution, you can find it here:
https://github.com/prusa3d/Slic3r/issues/2180
Thanks everyone, for your input.
Fair farren
Opublikowany : 30/04/2019 11:58 pm
