Slic3r missing items in slice
Seeyah
(@seeyah)
hello,
I am trying to print 2 parts. The first part printed and sliced fine with prusa slicer. the second is almost identical, but here ribs inside are not sliced. When I slice it with simplify3d, the STL slices correct and the ribs inside are present. anyone has an idea? I tried printing with S3D but the quality is not as good as with prusa slicer.
Postato : 29/04/2018 6:00 pm
Wally
(@wally)
Re: Slic3r missing items in slice
Have you been able to figure it out? I have a similar issue. I slice with Slic3r PE and there are layers missing on a piec of the part
I printed something from Thingiverse, and the print is just missing lines in one spot of the print.
Postato : 01/05/2018 4:09 pm
Kai
 Kai
(@kai-2)
I´ve had this on several objects that i got from thingiverse.
When you open it in MS 3d Builder you will possibly get a repair Message.
Just do so and save the file.
Now you should be fine slicing it with Slic3r PE.
Since my first problems with incomplete prints, i double check them in slic3r PE.
nec aspera terrent
Postato : 02/05/2018 10:55 am
Wally
(@wally)
Thanks for the advice!
Postato : 03/05/2018 4:50 pm
Wally
(@wally)
Wally
(@wally)
