Slic3r missing items in slice
hello,
I am trying to print 2 parts. The first part printed and sliced fine with prusa slicer. the second is almost identical, but here ribs inside are not sliced. When I slice it with simplify3d, the STL slices correct and the ribs inside are present. anyone has an idea? I tried printing with S3D but the quality is not as good as with prusa slicer.
Re: Slic3r missing items in slice
Have you been able to figure it out? I have a similar issue. I slice with Slic3r PE and there are layers missing on a piec of the part
I printed something from Thingiverse, and the print is just missing lines in one spot of the print.
I´ve had this on several objects that i got from thingiverse.
When you open it in MS 3d Builder you will possibly get a repair Message.
Just do so and save the file.
Now you should be fine slicing it with Slic3r PE.
Since my first problems with incomplete prints, i double check them in slic3r PE.
nec aspera terrent
Thanks for the advice!
