Slic3r 1.41.3 blocker/enforcer not working
bob.h7
(@bob-h7)
I've watched and read all I can find.
The modifier shows up in it's position with the model. When I go to slice there is no impact.
Yes, Auto Support is off.
Suggestions, please.
Publié : 18/04/2019 6:59 pm
bob.h7
(@bob-h7)
Re: Slic3r 1.41.3 blocker/enforcer not working
Reverted back to 1.41.2 and now blockers/enforcers seem to work.
Any thoughts why?
Publié : 18/04/2019 9:20 pm
vintagepc
(@vintagepc)
Membre
Show some screenshots of your model, modifier placement and settings. Without that we can only guess.
Publié : 18/04/2019 9:22 pm
bob.h7
(@bob-h7)
It seems to be working now, with 1.41.2.
If it ain't broke, why fix it.
Upgrading to 1.41.3 and making screen shots is sort of a PITA. 9Can I have two versions of Slic3r PE on the same pc?
Maybe someone else had the problem with 1.41.3 and had a quick answer. Maybe I'm the only one?
Any way, thanks for the offer.
Publié : 18/04/2019 11:21 pm
bob.h7
(@bob-h7)
False alarm.
I got it to work in 1.41.3. It was my logic/knowledge at fault.
Blocker only(?) works when auto generate is enabled. I thought auto generate had to be off whenever blocker or enforcer was used.
Publié : 18/04/2019 11:54 pm
