Sign printing/designing software
Bascule
(@bascule)
I'm looking to print a couple of very basic signs - basically a background sheet with some raised writing on there. I vaguely remember reading about a website or software which caters to that, but I forgot to bookmark it. Does anyone have suggestions?
Postato : 18/05/2021 1:36 pm
RE: Sign printing/designing software
It is very easy to do in Fusion 360, but that's probably overkill. I'm sure it can be done in OpenSCAD.
Postato : 18/05/2021 1:56 pm
Possibly Tinkercad.  Its online, is very simple to use and has several fonts available.
Postato : 18/05/2021 2:33 pm
1 persone hanno apprezzato
https://imagetostl.com/
Design something in Word/Powerpoint/Draw/CS ... save a PNG of the artwork; pipe it up to this or other sites like it (there's a ton of them).
Postato : 18/05/2021 6:14 pm
And use the color change feature in Slicer to make the text layers a new color.
Questo post è stato modificato 5 years fa da --
Postato : 18/05/2021 6:22 pm
Utenti
Posted by: @tim-2
I have used this to make signs and convert logos to 3D prints.  You could also make a basic design in Tinkercad.
Postato : 18/05/2021 8:06 pm
Bascule
(@bascule)
Posted by: @tim-2
Thank you kindly!
Postato : 18/05/2021 8:37 pm
Of course it can:
// Raised text in OpenSCAD
x_dim=100;
y_dim=20;
z_dim=5;
text_height=1;
cube([x_dim,y_dim,z_dim]);
translate([x_dim/2,y_dim/2,z_dim]){
    linear_extrude(height=text_height){
        text("Raised text", halign="center", valign="center");
Gives:
Postato : 18/05/2021 11:11 pm
Utenti
@diem
Thanks.  I just tested it and it works perfectly.
Postato : 18/05/2021 11:14 pm
