selftest error please check axis length axis x
Wile E. Coyote
(@wile-e-coyote)
We have a Prusa MK3+ since 2021 which we bought preassembled. Recently, I factory reset it and now want to run the calibration process, but I get an error message "selftest error please check axis length axis x". The mechanism moves smooth along the axis, no resistance.
This is a video where you can see the problem:
What can be the cause? How can we fix it?
This topic was modified 2 years temu by Wile E. Coyote
Opublikowany : 07/12/2023 4:35 pm
Cabiri-Prusa
(@cabiri-prusa)
RE: selftest error please check axis length axis x
I have just had this exact same failure. Hoping someone knows what the issue is.
Opublikowany : 08/12/2023 2:44 pm
1 ludzie polubili
Wile E. Coyote
(@wile-e-coyote)
If someone ends up here looking for a solution, I don't have it but I got our printer back into work. I simply ignored this calibration by selecting "no" when it asks just after turning the printer on, then I run the "first layer calibration" procedure to adjust the height of the nozzle, and now the printer is working again. 🤷‍♂️
Opublikowany : 12/12/2023 9:23 am
