Selftest continous loop
frontrange
(@frontrange)
After clearing yet another jam I can no longer get this MK3S to finish a selftest. I get no errors, as soon as it gets past the heatbed test and on to the hotend test it just starts again from the beginning, over and over....
Respondido : 08/03/2020 6:57 pm
RE: Selftest continous loop
Posted by: @steve_cranage
I would do a complete factory reset and try again. After the factory reset you have to recalibrate the printer.
Respondido : 08/03/2020 8:54 pm
frontrange
(@frontrange)
No help. As soon as it gets to "Hotend", it just restarts the calibration from the beginning.
Respondido : 08/03/2020 10:00 pm
@steve_cranage
You should contact the Prusachat. Login with your account and select the e-shop. After a few seconds the chatwindow appears on the right bottom. Deactivate addblocker and similar tools in your browser.
Respondido : 09/03/2020 3:39 pm
vintagepc
(@vintagepc)
Miembro
Is it resetting when it gets to hotend? If so I'm betting you have a short on your heater wires and it's crowbarring the power supply (before the fuse blows) causing the einsy to reset.
Respondido : 09/03/2020 4:08 pm
frontrange
(@frontrange)
Posted by: @vintagepc
I had convinced myself this wasn't the issue because I thought it was heating the nozzle, but when I checked to confirm, i was surprised to see that preheating also reset the printer, so yes, I'm now sure that is the problem. Thanks!
Respondido : 10/03/2020 4:29 pm
