Second layer failure
ben.g16
(@ben-g16)
Yesterday, I started to print a simple block.  I noticed the filament spooling into the air.  I thought it was an adhesion problem, so I started over.  After multiple tries over two days, including drawing very simple test models, the problem remains.
The first layer is no problem.  The second layer floats above the first layer too high for the filament to stick and forms a tangled mess. I tried choosing a different print setting, but no change.
Obviously, I can't print anything with this problem.
This topic was modified 6 years temu 2 times by ben.g16
Opublikowany : 12/06/2020 2:55 pm
ben.g16
(@ben-g16)
RE: Second layer failure
 Ok, found the problem.  My mistake.  I put a spool of PETG in instad of PLA.  They looked the same and I didn’t notice.  My bad.
Opublikowany : 12/06/2020 5:45 pm
@ben-g16
thanks for the feedback - small mistakes with big effects 👍
Opublikowany : 12/06/2020 5:50 pm
