SD Card Errors
bushwhackr
(@bushwhackr)
SD Card Errors
I have a MK3S kit that performs perfectly.  I updated the firmware to 3.9.0, and now I have a problem with the SD card.  When in the printer, the files are all read fine, and everything is OK.  When I put the SD card in a computer, it is either not recognized, or I get an error message that the card needs to be scanned and repaired.  Once it is repaired, it works fine and I can add gcode files.  This happens with two new SD cards and on two computers.  It seems that either there is a firmware bug or I have a hardware problem.
Postato : 02/07/2020 4:40 pm
Peter M
(@peter-m)
RE: SD Card Errors
On the computer, only remove the card after you unmount/eject the card through software, never remove card without ejecting the card.
See if you work like this, if it is gone.
Postato : 04/07/2020 4:23 pm
RE: SD Card Errors
Posted by: @bushmg1
Try to format your SD card with this tool: https://www.sdcard.org/downloads/formatter/index.html
Postato : 04/07/2020 4:57 pm
bushwhackr
(@bushwhackr)
RE: SD Card Errors
Thank you for the replies.  After more troubleshooting, I think the problem is the Windows 10 laptop and not the printer.  If I move the SD card between the printer and the Dell Desktop computer (also Windows 10), everything works fine.  However, once I insert the card into the laptop, I get the error message to repair the card.
Now to get started troubleshooting the laptop.  Thanks again for the help.
Postato : 04/07/2020 6:45 pm
Peter M
(@peter-m)
RE: SD Card Errors
Do the remove way I told you, if you do this you will never damage sd card(or hard disk), it is more work, but it is better to be safe.
I work like this, unmount or eject, then even if pc says remove, I still wait a little longer, then i remove it.(once i saw the pc did eject and mounted it again directly after ejecting).
Even people on work, that should be professional I had to explain this.
And a lot of normal users always just pull it out, it always works they say, bit this is very wrong.
Postato : 05/07/2020 9:44 am
Peter M
(@peter-m)
RE: SD Card Errors
Do you know par2.
Make a few files you can copie and check with par2, fill the card, and check the par2 files, you could also use checksum program.
Postato : 05/07/2020 9:46 am
bushwhackr
(@bushwhackr)
RE: SD Card Errors
@peter-m26, no I don't know par2, but I will definitely check it out.  Thanks for the tip.
Postato : 05/07/2020 5:05 pm
kayenhere1
(@kayenhere1)
RE: SD Card Errors
Posted by: @peter-m26
On the computer, only remove the card after you unmount/eject the card through software best ninjas, never remove card without ejecting the card.
I do the same again but still same got error, i am in trouble at shop
Questo post è stato modificato 6 years fa da kayenhere1
Postato : 06/07/2020 1:50 pm
