screw stuck
Brakovic
(@brakovic)
screw stuck
Hello,
Some filament was stuck in the noozle. I tried to open the engine by removing the four screws in the front. The last screw was stuck so I forced a little bit, but I wore it off.
Any Advice on how to unscrew it? Thanks.
Opublikowany : 22/01/2023 9:35 am
Netpackrat
(@netpackrat)
RE: screw stuck
Posted by: @brakovic
Hello,
The four screws on the front of the extruder motor?  You don't...  Put the other three back and be glad you couldn't get the last one out.
Opublikowany : 22/01/2023 11:04 am
Brakovic
(@brakovic)
RE: screw stuck
I tried that. But the screw is worn. The screwdriver does no longer stick in the screw.
Opublikowany : 22/01/2023 11:07 am
Fraser
(@fraser)
RE: screw stuck
There is information in dealing with a blocked nozzle at https://help.prusa3d.com/article/clogged-nozzle-hotend-mk3s-mk2-5s_2008 . It would appear that you have been trying to dismantle the stepper motor which is not such a good idea. If you can't get the screws back in you will likely need a replacement motor. If you get any problems then always visit the Prusa Knowledge Base for guidance before starting to take bits apart.
Fraser
Opublikowany : 23/01/2023 11:27 am
