Running extra fan off MK3S+ power supply?
Therevox
(@therevox)
Wondering if I can run an extra fan off t he MKS3+ power supply. Does anyone know how much current the printer is drawing from the power supply and if there's any headroom left?
I'm looking at 24V fans that draw 0.5A to be used in a little DIY HEPA filter setup, and I'd love to wire it right into the power supply if possible. Or connect to the eintsy board if there's extra jacks available for fans?
Publié : 31/03/2025 9:12 pm
RE: Running extra fan off MK3S+ power supply?
I suspect the mmu3, with 3motors and a controller. Draws more than half an amp
My mk3s supports the mmu3 on its power supply
If you don't have an mmu3. You should be ok.
Publié : 01/04/2025 11:31 am
Therevox
(@therevox)
Oh good call, I had no idea the MMU takes power directly from the printer. Does it connect directly to the power supply, or are there unused headers on the PCB that I can tap off?
Publié : 01/04/2025 5:39 pm
The MMU piggybacks the power leads on the bottom of the einsy controller board
Regards Joan
Publié : 01/04/2025 9:54 pm
