Retract a bit
Nelas
(@nelas)
Retract a bit
Hello my friends,
I would like  add a code to rectract a bit when finish the print to avoid the filament drop when is heating in the next  print.
Someone can help me?
Napsal : 01/02/2021 10:31 pm
RE: Retract a bit
You can add gcode to the end gcode section under print settings to do this. The problem is if you abort a print, the filament won't be retracted, so you don't know exactly what condition the printer feed is in at the start of a job. You have to add more gcode to the start gcode to make sure filament is feeding properly before starting the print.
Napsal : 02/02/2021 5:37 am
