Replacing fans with Noctua
Petra Cibulková
(@petra-cibulkova)
Hi Hi,
I would like to replace both fans with Noctune and completely redo the Hotend.
something like:
But I don't know which one I can use if 4-pin PWM or 3-pin
thanks.
Publié : 15/01/2023 11:47 pm
RE: Replacing fans with Noctua
3 pin
Publié : 16/01/2023 12:42 am
Petra Cibulková
(@petra-cibulkova)
Thank you, I'm trying to search here on the forum and elsewhere, if anyone has similar projects, please send them here 🙂
Publié : 16/01/2023 1:01 am
do Noctua do a turbine fan?
you may need to use the hidden experimental menu in the prusa knowledge base
unfortunately I cant find the link at the moment
joan
Publié : 16/01/2023 1:03 am
R&D
 R&D
(@rd)
https://help.prusa3d.com/article/experimental-menu-mk3-s-_161213
Publié : 16/01/2023 9:12 am
Stefan
(@stefan-3)
Not a good idea...
Because the Hotend cooling fan already is from Noctua, as stated by Prusa in the article linked above.
Keep the blades of the fan clean from dust and filament stringing and it is sufficient to cool the hotend.
For the part cooling fan, a Noctua axial fan creates much less pressure than the stock radial fan, so part cooling would be worse.
Noctua does not offer radial fans.
Publié : 16/01/2023 10:51 am
1 personnes ont aimé
k3lb3r
(@k3lb3r)
Membre
I made the mistake of upgrading the Noctua side fan with an A4x20, which shortens the x-axis (reduces the range of gantry travel) by the ~1cm difference in thickness, which means the printer can no longer calibrate itself :/
i'm sure i could deep-dive the forums and figure out how to home on a different limit but ultimately it's a waste to lose print bed real estate.
Publié : 23/07/2023 7:13 pm
