Repeat Problem
Scott Andreasen
(@scott-andreasen)
Utenti
Repeat Problem
hi, I have a problem that has happened three times. I tried to fix it twice but the problem persists.
Here is a description:
1. Extruder stops extruding part way through the print
2. Then the filament gets stuck and cannot be unloaded
Here is what I did to (try) to fix it
1. I took the extruder apart and removed the filament.
2. thinking heat creep, I replaced the PTFE tube. also ceased turning the printer off immediately after the print.
3. Did a cold pull.
This is what happened.
1. A few prints worked (like maybe 12 hours total)
2. Extruder stopped extruding
3. Filament got stuck in extruder and I could not unload.
So, I tried this:
1. Well, this is where me being a rookie comes in.... I took everything apart and tried to remove the filament again.
2. Ended up breaking a chunk off the Extruder Body
3. Purchased a new (genuine) Extruder body part from Prusa
4. Also purchased an entire new assembled Hot end: https://www.prusa3d.com/product/assembled-hotend-mk3s/
5. Installed everything
6. Calibrated everything. No errors.
2. Extruder stopped extruding -- the print that caused the problem was different than the other prints that caused this problem. Filament was different too.
So I'm back where I started for the third time.  My current thinking is to replace the gears that push the filament down. But I’m at a loss, so wanted to throw this out and see if any of you have some advice.
Thanks!
Questa discussione è stata modificata 2 years fa da Scott Andreasen
Postato : 14/10/2024 2:25 pm
