Repairing the lead wire connection on the print fan
Does anyone happen to know which lead wire goes to which pad on the pcb inside the print fan? I need to repair this while I wait on a replacement. Thank you!
RE: Repairing the lead wire connection on the print fan
Thank you!!
I would recommend you keep at least on spare. This will happen again.
Thank you!!
Print the service shelf - it will save your fans
In the print library is a oh so useful service shelf that hangs on the X horizontal rods. It is used to service the extruder body and designed to hold the fans without breaking their little wires.
Is this it?
https://www.prusaprinters.org/prints/3470-prusa-printers-service-tray
That's it! I have two of them. They save your fans.
Great idea. Thank you
Thanks for the link!
thank you!
Eventually, you arw going to damage the fan fires to the point where it cannot be repaired. I have been doing this for almost 4 years. Sometimes, it is time to swap it out.
Thank you!!
I don't thinks so, Why just, I don't think anything that adds to this can improve! can you explain how?
Does anyone know the polarity of the wires on the original fan? I need to replace mine and have an extra Fysetc DC5V radial fan.
I'm assuming that:
Red = Positive
Black = Negative
Yellow = Speed
Can anyone confirm this?
