Reboot when heatbed and nozzle are warmed up at the same time, but not when alone
Bruno
(@bruno)
I've got the strange situation where I can manually heat up the heatbed or the nozzle (using settings > temperature) and that works fine.
When I try to preheat using a preset, as soon as the nozzle and the heatbed need to be heated at the same time the printer instantly reboots.
I've tried printing by preheating nozzle and heatbed separately and that actually works until (of course) at some point need to be heated at the same time. Then mid-print the printer resets again.
I'm not sure how to diagnose what the issue is, it could be the power supply, or could it also be a faulty ENISY board? Event preheating the heatbed alone to 100c works without problems. Only if both nozzle and heatbed are heated the board reboots.
Any ideas on how I could diagnose the actual fault?
Respondido : 30/09/2020 9:30 am
Miembro
RE: Reboot when heatbed and nozzle are warmed up at the same time, but not when alone
Nope - Odd.  Have you contacted support or reported the problem?
Respondido : 30/09/2020 12:21 pm
Bruno
(@bruno)
Not yet, I first wanted to collect more information.
In the meantime I tried with a disconnected PSU panic cable, but it still resets.
Since heating per se functions I'm leaning toward a hardware problem on the EINSY board...
Respondido : 30/09/2020 12:27 pm
Posted by: @bruno-e
It is possible that there is a fault in the power supply and it does not provide enough power. I would at least measure the voltage.
Additionally I would also check the voltage carrying wires (24V) for corrosion and loose contacts.
Respondido : 30/09/2020 1:46 pm
