Re: SEQUENTIAL PRINTING: Override collision check?
Swami
(@swami)
Greetings fellow slicers 🙂
I'm confident a parts arrange will print sequentially w/o collisions, BUT Slic3r flags collision and terminates gcode creation 🙁 I've played w/ the setting to no avail 🙁 Set 'Clearance' 'Radius'/'Height' to extremes: 0, then 1000, in case I misunderstood things (clearance needs, or provided?). Regardless, one of those should work I have to think. But I'm still doing something "wrong".
TIA.
Swami
The Slicinator
Respondido : 13/02/2019 7:36 am
toaf
 toaf
(@toaf)
maybe try not instanced copies?
nope wasn't that. it works with instances in alpha 5
yup acting odd. now I cant do iit. but first time it did work
Respondido : 13/02/2019 7:43 am
Swami
(@swami)
Hi Chris,
Thx for the prompt reply, and testing.
Yeah, acting "oddly" 🙁
Hm?...
P.S. Gonna do some testing in stable version to eliminate alpha as source of problem...
Respondido : 13/02/2019 9:47 am
Swami
(@swami)
- BTW, got it to work w/ 2, then 3, but failed w/ 4.
- Deleted 1, then surprisingly it failed where it had just succeeded previously.
- Hm?...
Respondido : 13/02/2019 9:49 am
toaf
 toaf
(@toaf)
ya, its borked. I cant define what makes it work. but I did have 4 work and it was instanced copies.. but I cant explain why
Respondido : 13/02/2019 9:50 am
vintagepc
(@vintagepc)
Miembro
I think there is an arrange bug somewhere as well that confounds this problem, i.e. if you arrange instanced parts it will not place them front-to-back, and if you print back parts first the extruder wires will hit them.
I thought there was an option to pause for part removal when doing sequential... maybe that will "override" to tell it other parts are gone?
Respondido : 13/02/2019 1:18 pm
toaf
 toaf
(@toaf)
I bet that's it.
Respondido : 13/02/2019 8:05 pm
Swami
(@swami)
- Anybody heard anything on sequential printing ('Printer Settings'>'Complete individual objects')?
- Just tried in Slic3r PE, 1.42.0-beta1 (latest), but no go 🙁
- Actually, keeps reporting: "Some objects are too close...", even when that's clearly not the case 🙁
- Are we missing something? 'Cause this should be a basic functionality.
- BTW, I'm especially interested in getting this to work on a current job that requires PETG (read "stringy").
Respondido : 25/03/2019 4:22 am
