Random seam location not working
joenunez12
(@joenunez12)
I have a prusa MK3S with the newest firmware and the newest version of PrusaSlicer. I'm trying to print something rotationally symmetric with a random seam, but when I use that setting in the slicer, it prints with what I think is the 'furthest' seam position (two visible seams along the height of the print on opposite sides). I have tried using both the mac and pc versions of the slicer and the problem occurs in both.  Has anyone else encountered this problem?
Postato : 14/02/2020 2:19 am
rmm200
(@rmm200)
RE: Random seam location not working
When in doubt - try a different slicer.
Cura is really good and has a few bells and whistles that Prusa does not - yet - like tree supports.
Postato : 14/02/2020 2:49 am
Posted by: @joenunez12
I would prefer to use the "aligned" seam position for best results. Here an example of the different seam positions:
https://forum.prusa3d.com/forum/original-prusa-i3-mk3-zusammenbau-und-fehlersuche-bei-den-ersten-druckversuchen/verformung-bzw-fehler-im-temperaturtower/#post-189235
As you can see, all seam position options are working proper. The seamposition also depends on the design of your printpart.
Postato : 15/02/2020 10:20 pm
